Home Forums Classifieds Classifieds – Kart Packages 2003 Anderson Superkart For Sale
This topic contains 1 reply, has 2 voices, and was last updated by  Todd Baker 11 months, 2 weeks ago.
  • #79862
    Danny Weyand
    This 2003 Anderson Superkart was owned by a good friend of mine that just passed away. His widow has asked me to sell the kart for her. I maintained the kart for my friend for most of its racing life. A 1998-2000 Yamaha 400cc 4-stroke is currently mounted to the kart, but it also comes with a 1996 Honda CR250 that was used prior to mounting the Yamaha. The kart was not used that much and is in good condition. It is located in Las Vegas and comes with the following:
    2003 Anderson Superkart Chassis
    Kelgate fully adjustable front end
    Rack and pinion steering
    Drilled and slotted front rotors with four piston calipers
    Drilled and slotted rear rotor with six piston caliper
    Kelgate master cylinder with remote brake bias
    Kelgate 35mm rear axle with Kelgate fixed gear hub and split gears
    Momo steering wheel with quick release hub
    Hand operated clutch
    AutoMeter coolant temperature gauge
    Ron Davis rear mounted aluminum radiator
    Aluminum fuel tank (center mounted). Modified to accommodate both engines
    1998-2000 Yamaha 400cc 4-stroke engine (currently mounted)
    1996 Honda CR250 2-stroke engine with pipe, carb and mount (was mounted)
    Three sets of 6″ wheels and tire bead breaker
    Electrically operated scissor kart stand
    4′ X 8′ open kart trailer
    The kart will also come with any spares that are with the kart. This could be a great opportunity to own a superkart or buy it to part it out. $3,250 obo.
    Please call Danny Weyand with any questions. Pictures available on request.
    626.298.3470 or dannyweyand@gmail.com
    Todd Baker
    Can you send any pictures? You can text them if needed. 408 313-9730
