Home Forums Tech Talk AIM GPS Module – Ext Power or Not
This topic contains 10 replies, has 4 voices, and was last updated by  tony zambos 2 years, 11 months ago.
Viewing 11 posts - 1 through 11 (of 11 total)
  • #40907
    Wondering what the common practice is for powering a GPS module, external battery or internally by the M4?
    #40945
    Bill Boxell
    Tony,
    If the external battery is there, use it. I feel the GPS works a touch better on 12VDC but even if there is no difference it’ll save you money buying 9VDC batterys by the multi pack.
    Bill
    #40965
    thanks Bill
    #41956
    Jason Bane
    I had issues with regular alkaline batteries. Brand new battery would give low battery sign as soon as GPS was hooked up. I switched to lithium battery and I have 3 race weekends on same battery and still going. Order lithiums from battery junction, much cheaper than picking them up in a store.
    #41976
    Jason,
    Thanks for the tip. My system includes an M4-2t and a gold eBox. The eBox gives me the power of two extra 9v’s. Which batteries from Battery Juction are you using?
    #41993
    Jason Bane
    I’m using these, so far so good, I just have the one that fits inside of my M4-2T, no Ebox for me. …..http://www.batteryjunction.com/duracell-dl10604-9v-lithium.html.
    #41995
    Thanks Jason. I completely missed this battery the first time I looked at the stie.
    #42008
    Boyd Atherton
    I’m using a 3s Li-Po RC car battery to power Mychron 4 and GPS.  It’s 11.1 volts and it charges to about 11.9 volts.   It’s been great, lasts so much longer than a 9 volt.  No more buying a 9 volt for $6 at the gas station I forgot to get one earlier.  Here’s a link to the one that I have.
    http://www.hobbyking.com/hobbyking/store/__7636__ZIPPY_Flightmax_2200mAh_3S1P_25C.html
    I’m also using a 4s Li-Po as the main kart battery to start my PRD.  Hardly ever have to charge it and it weighs about 600 grams.
    #42010
    Boyd,
    Thanks for the input. I’m assuming that you are connecting the battery to hub to power both the M4 and GPS module.
    #42011
    Boyd Atherton
    Yes.  Connected to the power leads on the 2 port data hub that comes with the GPS.  I bought a couple of the female plugs would plug in the existing plug on the battery and put flat blade connectors on to plug into the Mychron wiring.
    I decided to go this route because of how quick the Mychron with GPS would run down a 9 volt.
    #42012
    Boyd,
    Appreciate the input. thanks
