Home Forums General Karting Discussion Aftermarket brake question
This topic contains 14 replies, has 4 voices, and was last updated by  Curtis Cooksey 2 years, 6 months ago.
  • #58010
    Bryan Williams
    If I was to buy an after market brake system to replace my top kart master cylinder and calipers who’s better <span style=”color: #444444; font-family: Arial, Helvetica, serif; font-size: 12px; line-height: 21px; -webkit-text-size-adjust: auto; background-color: #efefef;”>Righetti or mcp and anyone have any experience with either? I’m sure a brembo set up would be best but I’m not looking to spend 1200$ thanks.</span>
  • #58012
    William Martin
    MCP master cylinder & Wilwood Caliper. You may need to make your own mounting bracket(s), but those parts will last approximately forever, compared to most anything you can get from Europe. The Euro guys have some nice calipers now, but still can’t seem to make a decent master cylinder, ie. one that is not designed to suck up dirt & fail “soon”. Oh, one problem with the Wilwood caliper: you may have to figure out how to get less rear brake…the rotor needs a lot of holes in it to reduce the available friction surface, or it will be “hair trigger” sensitive. At least that’s how mine worked out…
    Bill
  • #58013
    Bryan Williams
    Right now I am running a drilled and full float disk.  are these the correct ones?
    <span style=”line-height: 1.5;”> </span>
    <span style=”line-height: 1.5;”>So which one would you use. They all just seem to small. Am I not looking at the correct ones?</span>
  • #58014
    Bryan Williams
  • #58051
    Personally I would go with all MCP.
  • #58053
    Bryan Williams
    I see mcp has the euro style or their reg style for master cylinder and calipers. Think one has a benefit over the other?
    • #58065
      William Martin
      Don’t really know. My only criterion is that the piston shaft has a real dirt seal in front of it. The vented reservoir is also good with self-retracting pads in the caliper. I haven’t looked at the MCP caliper in years, is it a self adjusting style? If so, no problems with using that as far as I can tell. It will certainly be easier to build your brake system with parts from the same place… :-) I just like to do it the hard way I guess!
      Bill
  • #58064
    William Martin
    Right now I am running a drilled and full float disk. are these the correct ones? <span style=”line-height: 1.5;”> </span> <span style=”line-height: 1.5;”>So which one would you use. They all just seem to small. Am I not looking at the correct ones?</span>
    Have a look at the rotor that Schockwave did for the Wilwood rear caliper, it isn’t really available any more, but illustrates what they had to do to get the friction down to where the brakes didn’t just instantly lock up with little pedal pressure. It was a solid rotor, about 3/8″ thick, with a bunch of holes drilled in it…not so much for cooling, I think!
    About the seeming small: Do you mean the calipers at the Summit link? If so, it’s deceiving, that rear caliper is massive for a kart.
    Bill
  • #58066
    Anytime you retrofit a brake system you have to consider the mounting bolt spacing, spacing for the rotor and interference from frame members. I would think the TopKart would use the euro system.
    I like MCP because you can get them everywhere and they’re always gonna be around. I have the euro system on my Margay and the standard system on my Coyote and very happy with both.
  • #58093
    Curtis Cooksey
    The new Righetti Ridolphi set-up is the best brake you can buy for this price. The only brake that is better in my opinion is probably the OEM CRG stuff.
    Check it out: http://www.accelerationkarting.com/completerearbrakesystemma20.aspx
  • #58094
    Bryan Williams
    The new Righetti Ridolphi set-up is the best brake you can buy for this price. The only brake that is better in my opinion is probably the OEM CRG stuff. Check it out: http://www.accelerationkarting.com/completerearbrakesystemma20.aspx
    I have been eyeballing this set up. But I would still have to buy a rotor hub and come up with a mounting bracket and do not know if I want to spend 800$ on just breaks.
  • #58095
    Curtis Cooksey
    Bryan, brakes are very important to lap times. These brakes will lower your lap times. Total price with the hub and mounting bracket is $725.18. How much would you pay your motor builder to make your motor faster?
  • #58103
    That RR system looks allot like CRG Ven05
  • #58105
    Bryan Williams
    so very true.
  • #58399
    Curtis Cooksey
    Bryan, here is a less expensive option: http://www.accelerationkarting.com/righettiracingcompleterearbrakesystem.aspx
    I also have this exact system that is used. Since it has been used a few races we can sell it for about $150 less than a new system. If you are interested in the used system call Acceleration 1-888-466-5278 or email techsupport@accelerationkarting.com
