Home Forums General Karting Discussion 15hp 420cc powerfist remove governor how?
This topic contains 2 replies, has 2 voices, and was last updated by  Liam robinson 2 years, 3 months ago.
  • #58027
    Liam robinson
    Hey I just got a 15hp 420cc powerfist motor and I’m wondering how to remove the governor because the throttle does not make it go faster. Thank you for any help
    Are you talking about the harbor freight predator engines?
    If so, then all you gotta do is remove tank, throttle linkage and lever, side engine cover (be careful not to break off the gasket)
    Remove the white plastic gear ( it will be a challenge removing the “C” clip retainer) bend the inside part of throttle linkage away from crank shaft, put everything back together, cut carburetor black plastic linkage holder ( you will need to order a new throttle linkage kit and throw away the original one.
    Anyhow, hope this helps, I’ll try to post a video, if you can’t get it to work.
    Liam robinson
    Check this thread too people are helping http://www.diygokarts.com/vb/showthread.php?t=31663
