--> Reply To: Jet-Tech Max Jettign Software Question – ekartingnews
Home Forums TaG Rotax Max Jet-Tech Max Jettign Software Question Reply To: Jet-Tech Max Jettign Software Question
#16715
Ambrose Buldo
Yes – I used old slide and spring.  Since them, I replaced the throttle cable and put a new spring on it.
Johns reply on fuel pump pipework got me thinking.  The line from the crankcase to the  fuel pump is much longer then on the other motor.  I will shorten it up as much as possible.  Also I notices this engine uses regular fuel line for the pump plumbing whereas the other motor as much smaller in diameter (and more flexiable) line.  I am going to change over.
