Home Forums 250 Superkarts Anderson rear axle bearing Reply To: Anderson rear axle bearing
#7877
Sam Moss
Not sure on where you could get them in the US but the ones we tend to us are SKF Y Bearings with grub screws, 35mm ID, 72mm OD. They are all a standard size of 19mm to fit in the bearing carriers.
They only options is that you can have a choice of speed and load rating. By guessing I presume we use the highest with part number of YAR-207-2RF
http://www.skf.com/group/products/bearings-units-housings/ball-bearings/y-bearings/y-bearings-with-grub-screws/index.html
