--> ekartingnews
Home Forums TaG Yet another Leopard "No Spark" thread… Reply To: Yet another Leopard "No Spark" thread…
#29692
Avi Goldberg
Norm,
If you did the “strike test” and it sparked, then you have either a power box issue or a defective stator. A wiring problem could also explain those symptom. If you have a DVM you may measure the resistance of your stator and use the values I got as a reference to compare to the measurements you take despite you having a slightly different stator. Actually you have two stators so you can compare one to another unless both are bad. Also measure the voltage on the wire going into the coil while pressing the start button and see what you get. Write the results here and we’ll take it from there.
Avi
